konečně jsem dostal odpověď na co je ta modrá ledka:
What's new in 6.33.5 (2015-Dec-28 09):
*) arp - show incomplete ARP entries;
*) btest - fix potential crash after btest release;
*) btest - improve UDP tx rate precision;
*) crypto - fixed kernel failure in talitos HW encryption;
*) dhcpv6-client - fix DNS address assignement;
*) dhcpv6-client - set correct parameters when rapid commit is used
*) e-mail - do not reset server address after changing configuration;
*) fastpath - fixed possible kernel failure on multi core systems;
*) fetch - added 30 second connection time-out;
*) hotspot - added missing favicon.ico in hotspot html pages;
*) kernel - general improvement for core process scheduling;
*) led - add WLAN led to RB951Ui
*) log - log link up/down events only when link actually has changed its state;
*) lte - improve support Sierra Wireless 320U;
*) lte - speed up first time connection to LTE network on SXT LTE;
*) net - apply slave config only if master config has been changed;
*) net - do not show L2MTU in VLAN compact export;
*) netwatch - make work with ping time-out more precise;
*) ppp - make PPP active print radius & !radius conditions work;
*) romon - do not accept multicast id;
*) romon - fixed crash on RoMON if fast-path was active;
*) smb - show correct interface name in SMB debug logs;
*) ssh - fix session clean-up;
*) sshd - resolved shared secret mismatch issue;
*) tile - fixed kernel failure on HW encryption;
*) webfig - didn't show zero values in CRS ingress/egress VLAN translation rules;
*) winbox - added + & - to IGMP proxy MFC;
*) winbox - added LCD menu for RB3011;
*) winbox - allow to specify traffic-monitor threshold in k & M units + specify that those are bits;
*) winbox - show fast-path per interface counters.
