Situacia je nasledovna podla obrazka https://imgur.com/a/Agauf Potrebujem aby sa videli pc zo siete 192.168.1.0/24 a 192.168.80.0/24
PC ktore su v 192.168.80.0/24 vidia IP adresy v 192.168.1.0/24 (ale nejak ignoruju DNS, vidia len IP adresy)
PC ktore su v 192.168.1.0/24 nevidia vobec siet 192.168.80.0/24.
CO sa tyka smerovania, tak som to na MK nastavil takto
IP > route
[admin@MikroTik] > ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 90.75.75.1 0
1 ADC 90.75.75.1/32 90.7575.69 pppoe-out1 0
2 ADC 192.168.1.0/24 192.168.1.1 ETH2_LAN-KLIENTS 0
3 A S 192.168.80.0/24 192.168.1.158 1
[admin@MikroTik] >
To je routa cislo 3.
A v LEDE (openwrt) som nastavil v Network > Static Routes
Interface -LAN
target - 192.168.1.0
Netmask - 255.255.255.0
Gateway - 192.168.1.1
Route type - unicastAle ked dam ping zo siete 192.168.1.0/24 na PC v 192.168.80.0/24, tak dostanem odpoved
From 192.168.1.158 icmp_seq=4 Destination Port Unreachable
