Ahojda,
mam zkusenost s timto a mohu vrele doporucit.
NETCOM FM SWOA7424S-SFP
24 x SFP 100Mbps, 2x SFP 1Gbps,2x combo SFP/RJ45 smart
16.795,50 Kč
dovozni cena bez DPH
Features
8K address table for auto-learned unicast addresses.
Jambo frame supports up to 2048 bytes.
802.1p and Port based QoS package classification with 4 priority queues.
4K 802.1Q based VLAN
Port based VLAN.
16 Protocol based VLAN.
13 trunk groups of up to 8 member ports for flexible load distribution control and fail-over function.
802.1d Spanning Tree Protocol, 802.1w Rapid Spanning Tree Protocol.
By-port egress, ingress, bi-direction rate control.
Storm Control
802.3x flow control for a full-duplex mode and collision-based backpressure for a half-duplex mode.
User configurable port mirroring supports ingress/egress/both data flow monitoring on one or more ports.
User account assignable to one of the two access privilege levels.
On-line firmware upgrade.
Dual power supply option provide power redundancy with status monitoring features.
Network Management
Web page management
Port Configuration
Gigabit ports: two optional standard SFP based 1000Base-X ports plus two 100/1000M SFP and 10/100/1000M RJ45 combo ports.
Twenty-four standard SFP based 100Base-FX ports
Pokud by jsi chtel neco narocnejsiho je tu pak:
NETCOM FM SWOA7424M-SFP
18.510,75 Kč
nebo
NETCOM FM SWOA8026M-SFP
26 x SFP 1Gbps, L2, SSH,SERIAL,WEB
20.246,40 Kč
dovozni cena cena bez DPH
Features
Jumbo frame supports up to 2048 bytes.
Port based VLAN.
MAC based VLAN
Guest VLAN
GARP/GVRP
Manual, static and dynamic port aggregation
By-port egress, ingress and bi-direction rate control
Multi-combination of MAC address, VID and Port binding
Static and dynamic MAC addressing
Blackhole MAC address filtering
IGMP Snooping
DHCP Snooping
Dynamitic ARP Inspection (DAI)
DHCP and ARP rate limit
Multicast VLAN Registration (MVR)
Link Layer Discovery Protocol (LLDP)
Storm Control for any combination of multicast, broadcast and DLF traffic
Access Control Lists (ACL)
Support port isolation
Secure Shell (SSH) v2.0
802.1x Port-based access control and MAC authentication
Loopback detection (LBD)
SNMP V1, V2c, V3
RMON statistics, history, alarm and event
SNTP
Web-based network management and Command Line Interface (CLI)
Supports port and VLAN management
Port Redirection
User account assignable to one of the three access privilege levels
Configuration file backup and restore
Dual power supply option provideoptions provide power redundancy with status monitoring features
Add your features here (we do customization, please contact us for details)
Network Management
SNMP v1/v2c/v3
Web page management
Telnet and RS232 console management
Network Protocol and Standards
IEEE.3, 802.3u, 802.3z, 802.3ab, 802.1d/w/s, 802.1p, 802.1q, 802.1v, 802.1ad, 802.3x, 802.1x
IEFT SNMP, RFC 1112/2236 IGMP, RFC854 Telnet, RFC 1123/1493/1643 MIB
Port Configuration
Gigabit ports: two standard SFP based 1000Base-X ports plus two 100/1000M SFP and 10/100/1000BaseTX RJ45 combo ports
/Josef P.
